enable ntp
enable ntp
Description
Enables NTP globally on the switch.
Syntax Description
N/A.
Default
NTP is disabled by default.
Usage Guidelines
N/A.
The following command enables NTP globally on the switch:
enable ntp
This command was first available in ExtremeXOS 12.7.
Platform Availability
